I expect Edward or Jon will come back to you soon but, in the meantime, check the online manual here.
The actual line in the manual is "All consoles can store a total of 10,000 cues across the playbacks."
Hi all,
David's picked out the key here - the total number of cues that can be stored in a single show file is 10,000. These could all be in a single playback (the maximum cue number is 9999.99), or more likely, you will have cues recorded on multiple playbacks.
Of course, this is theoretical - I think the biggest ZerOS show file I've ever seen had just under 2000 cues in total.
