Techie_v2 Posted December 4, 2022 Report Share Posted December 4, 2022 I know its best practice to use a terminator in your last fixture in a dmx line but if that fixture has both 3 and 5 pin sockets, should you put on in each? Thanks Quote Link to comment Share on other sites More sharing options...
kgallen Posted December 4, 2022 Report Share Posted December 4, 2022 No, just one. Otherwise you will double-terminate - the two 120 ohm resistors will be in parallel resulting in a 60 ohm termination which is the incorrect termination for a 120 ohm transmission line. 2 Quote Link to comment Share on other sites More sharing options...
Techie_v2 Posted December 7, 2022 Author Report Share Posted December 7, 2022 But if using a splitter, put one on the last fixture on each split correct? Quote Link to comment Share on other sites More sharing options...
Davidmk Posted December 7, 2022 Report Share Posted December 7, 2022 1 hour ago, Techie_v2 said: But if using a splitter, put one on the last fixture on each split correct? Yes. (Nice short answer 😀) Quote Link to comment Share on other sites More sharing options...
van den abbeele Eric Posted December 7, 2022 Report Share Posted December 7, 2022 Hello, I systematically use splitters (2-way, 4, 6 and 8-way) generally having around 70 LEDs (Moving & Static projectors) plus traditional lighting. This on a relatively large stage for "Moselle" department. Stage of 15m X 9m, dance floor (with in fact backstage included 26m X 10m) So it has long DMX lengths. The grill being between 6 to 7m high. So to limit the worries of lengths in DMX, I have to use some DMX Splitters (4, 6 and 8 DMX outputs) and indeed I do not put a cap on each free output of the splits with only DMX 3 as with those that have DMX 3 and DMX 5 outputs. normaly all is working good. thank ----------------------------------------------------------- Bonjour, J'utilise systématiquement des splitter (2 voies, 4, 6 et 8 voies) ayant en general en alentour de 70 Leds (projecteurs Moving & Statique) avec en plus tout ce qui est éclairage traditionnel. Cela sur une scène relativement grande pour le département de la Moselle. Scène de 15m X 9m, tapis de danse (avec en fait coulisses comprises 26m X 10m) Donc il a de grandes longueur DMX. Le gril étant entre 6 à 7m de haut. Donc pour limiter les soucis de longueurs en DMX, je suis obligé d'utiliser un certain de Splitters DMX (4, 6 et 8 sorties DMX) et en effet je ne mets pas de bouchon sur chaque sortie libre des splits avec uniquement le DMX 3 comme avec ceux qui ont des sorties DMX 3 et DMX 5. Normalement tout va bien ainsi. Une bonne fin de journée Eric Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 4 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 4 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 10 LS200 - Spot 200w // 19 Wash Par 12 X 18W // 12 BOWLDER 12X40w WASH // 12 PARZOOM 19 X 15w // 7 LY 400 - BSW CMY LED 400w Link to comment Share on other sites More sharing options...
Edward Z88 Posted December 7, 2022 Report Share Posted December 7, 2022 Hi All, To confirm, there is no need to terminate "unused" outputs of a DMX splitter. You only need to terminate the DMX line if there are "receivers" on the DMX line. Edward Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
