discover Posted November 1, 2023 Report Posted November 1, 2023 With FLX S24 Version 7.14 and Library 4.01.01 Fixture Showtec Shark Wash One and Fixture Showtec Shark Zoom Wash One work only with 15 Channel mode. May I request to correct the library of the 8 channel mode?
kgallen Posted November 1, 2023 Report Posted November 1, 2023 Hi @discover If you're desperate, I've attached my own fixture profiles for these fixtures and modes. (The ones in the library might be based on these but Edward possibly rebuilt them in the GDTF editor). Regards, Kevin Showtec.ift
Edward Z88 Posted November 2, 2023 Report Posted November 2, 2023 Hi @discover The Showtec Shark Wash One has a 7-channel mode. The Showtec Shark Zoom Wash One has an 8-channel mode. Please could you describe what specifically isn't working with these modes? Does Pan/Tilt work? Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
discover Posted November 3, 2023 Author Report Posted November 3, 2023 On 11/1/2023 at 8:59 PM, kgallen said: Hi @discover I've attached my own fixture profiles for these fixtures Thanks a lot, Kevin 😀 How do I import the *.ift file? In the (german) user manual I cannot see it.
discover Posted November 3, 2023 Author Report Posted November 3, 2023 21 hours ago, Edward Z88 said: Hi @discover The Showtec Shark Wash One has a 7-channel mode. The Showtec Shark Zoom Wash One has an 8-channel mode. You are absolutely right 🙂
discover Posted November 3, 2023 Author Report Posted November 3, 2023 21 hours ago, Edward Z88 said: Hi @discover Please could you describe what specifically isn't working with these modes? Does Pan/Tilt work? In this mode, thex do not light up raising the fader.
Edward Z88 Posted November 3, 2023 Report Posted November 3, 2023 1 hour ago, discover said: In this mode, thex do not light up raising the fader. I have doublechecked the Shark Wash One 7-channel mode, and the Shark Zoom Wash One in 8-channel mode. As these modes do not have colour mixing, you will need to choose a colour using the "Colour Mix" parameter to achieve light output. To do this, raise the fixture's fader, tap the "Colour" tab at the top, and then press the button in the middle of the "Colour Mix" parameter's encoder wheel. This will show all of the available colours, allowing you to tap the colour you want. You can then tap the encoder's button again to close. You could then store this colour as the fixture's default colour if you wanted to, so that the next time you raise the fixture's intensity, it comes on in this colour. Please click the link below for information on customising a fixture's default parameter values... https://www.zero88.com/manuals/zeros/controlling-fixtures/defaults I hope this helps. Please let us know if you have any questions. 1 Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
kgallen Posted November 3, 2023 Report Posted November 3, 2023 4 hours ago, discover said: How do I import the *.ift file? In the (german) user manual I cannot see it. Hi @discover I will let you follow @Edward Z88's instructions first. If subsequently you need to load "user created" fixture definitions, you just load them with Setup->Load (with the IFT file(s) on a USB stick of course). Here is the entry in the English manual: https://www.zero88.com/manuals/zeros/setup/load/fixture-files-2 Good luck, I hope you get your lights working! 1
discover Posted November 9, 2023 Author Report Posted November 9, 2023 On 11/3/2023 at 11:43 AM, Edward Z88 said: I hope this helps. Please let us know if you have any questions. Thanks, Edward I have learned, followed your instructions and set-it up accordingly. This has worked out. 😀 My most important take-away of this post is to understand the modes and eg the limitatios of the simplier mode (in this case colour mixing). - In this case, I go for the higher mode (15 Channel) which makes life easier.
Edward Z88 Posted November 10, 2023 Report Posted November 10, 2023 15 hours ago, discover said: I have learned, followed your instructions and set-it up accordingly. This has worked out. 😀 15 hours ago, discover said: - In this case, I go for the higher mode (15 Channel) which makes life easier. Excellent - pleased to hear it. Let us know if there's anything else we can help with. Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
