- Past hour
Hi Archie, On Phantom, If I try and add a fixture via [Setup] [add fixtures], I can only enter fixture numbers starting at 101. If I delete a dimmer channel first, then I can enter the fixture number of the deleted dimmer channel. which makes sense, so will do this first. I have changed the flash button to select, as you described. I will try on the real desk, once at the venue. Thanks for your help. Paul PS. With all the desks you own, you must have a big garage! -
Hi @Muller Light, You can patch your RGBW fixture onto the faders by assigning it a fixture number of 1-48 (or 1-96 if using a Solution XL), and the fader will control the intensity. To control colour, the fixture must be selected. Solution consoles don't automatically select fixtures when channel faders are raised like FLX and FLX S consoles do, so you would need to select it manually. You can turn the channel flash buttons below the faders into fixture select buttons via SPECIAL -> Channel button mode -> Select. This replicates the behaviour of the select buttons on FLX and FLX S - tap to select, tap again to deselect. The button's yellow LED will illuminate when that fixture is currently selected. Once the fixture is selected, you can control the colour in the same way as fixtures that are on the MFKs. Hope this helps, Archie -
So, if I have a light that is, say, RGBW + dimmer level, how do I setup the solution to have it as fixture number 1, so I can control the level with the fader and the colour with the MFKs and wheels? -
That’s great news! Thanks for confirming and no shame in asking here!
Just been at the theatre doing a check…. Yes, it’s the power supply! You’re right, nothing wrong with the dimmer. Scratch this post. many thanks, Zulu
