- Past hour
In my years working in IT there was "established wisdom" that you don't install even numbered releases (especially 0 releases) these generally contain new features and that often means new bugs. Odd numbers are usually bug fixes for the preceding one. Not always true of course but worth thinking about. There is also a theory of software decay. Essentially changing software can introduce bugs, even in the unchanged parts. This accelerates with the number of changes so, at first, very few bugs are introduced but, as the software becomes more complicated and new changes are built on top of old ones the number of bugs per change increases. Again, not always true but something to bear in mind as, eventually, all you are doing is fixing the bugs caused by fixing bugs. As the comments in one program I had the "pleasure" of working on said "this program is like an old car, you set out to change the air filter and end up replacing the engine" đ
I updated to 8.0.1 prior to programming my current show. Iâm not the most demanding user but I did manage to make 8.0.0 crash a couple of times when programming the previous show (probably when fiddling with palettes). Iâve not had any problems at all with 8.0.1 so it seems pretty stable to me. Iâm a relatively new user so I couldnât comment on it compared to the 7.x.x versions but it definitely seems more stable than 8.0.0. It didnât introduce any new features compared to 8.0.0 and was just a bug fix.
Bonjour, Je rencontre toujours des problèmes concernant les enregistrements dans les playback avec des parallèles zoom je vois systÊmatiquement le zoom bouger alors que je ne le voudrais pas comment procÊder ? Merci
Hi Archie, On Phantom, If I try and add a fixture via [Setup] [add fixtures], I can only enter fixture numbers starting at 101. If I delete a dimmer channel first, then I can enter the fixture number of the deleted dimmer channel. which makes sense, so will do this first. I have changed the flash button to select, as you described. I will try on the real desk, once at the venue. Thanks for your help. Paul PS. With all the desks you own, you must have a big garage! -
Hi @Muller Light, You can patch your RGBW fixture onto the faders by assigning it a fixture number of 1-48 (or 1-96 if using a Solution XL), and the fader will control the intensity. To control colour, the fixture must be selected. Solution consoles don't automatically select fixtures when channel faders are raised like FLX and FLX S consoles do, so you would need to select it manually. You can turn the channel flash buttons below the faders into fixture select buttons via SPECIAL -> Channel button mode -> Select. This replicates the behaviour of the select buttons on FLX and FLX S - tap to select, tap again to deselect. The button's yellow LED will illuminate when that fixture is currently selected. Once the fixture is selected, you can control the colour in the same way as fixtures that are on the MFKs. Hope this helps, Archie -
So, if I have a light that is, say, RGBW + dimmer level, how do I setup the solution to have it as fixture number 1, so I can control the level with the fader and the colour with the MFKs and wheels? -
Thatâs great news! Thanks for confirming and no shame in asking here!
Just been at the theatre doing a checkâŚ. Yes, itâs the power supply! Youâre right, nothing wrong with the dimmer. Scratch this post. many thanks, Zulu
kgallen started following Betapack dimmer packed up.
Betapack 1 are solidly reliable so this is surprising to have a âtotal deadâ. There is no overall fuse in the unit as they can be wired single or 3 phase delta or star. Are you sure your supply is ok? Check your supply MCB/RCD first if you havenât. Does an Act 6 work in the same supply socket? The Betapack power led should be lit (red or green depending on analogue desk supply polarity). None of the channel fuse neons should be lit. Can you investigate more and provide more info?
