Hi everyone, I’ve been a long-time fan of using Zero 88 consoles for my live production setups, but lately, I’ve been looking into upgrading the server hardware that sits behind my complex visual and lighting environments. As I start integrating more media servers and heavy-duty real-time rendering software into my workflow, I’ve found that my current hardware is starting to show its age. I’m currently planning a massive workstation upgrade and I’m curious if anyone here has experience with extreme-density memory configurations for lighting control servers. I’m looking at moving to a setup with 256GB of DDR5-5600MHz (PC5 44800) memory. It feels like a massive leap, but I’ve noticed that when running multiple high-resolution pixel-mapping outputs alongside my console software, my current system occasionally stutters during complex scene changes. One specific point I’m worried about is the memory latency; while the bandwidth on these PC5 44800 kits is fantastic, I wonder if the sheer size—running 256GB total—might introduce stability quirks I haven't accounted for in a production environment. I’ve always focused on the reliability of the lighting hardware itself, but it seems like in our modern age, the console is only as stable as the workstation pushing the data. Has anyone here experimented with scaling their server memory to these kinds of levels, or do you find that for professional lighting control, we are still better off with smaller, faster, and more streamlined configurations? Is the overhead of such a high memory capacity even necessary for our industry, or am I just over-engineering my rig?
fipex10696 joined the community
I am also a Theatre Tech for a College and can sympathise with your situation. I'm working with the full size FLX so apologies if some of my workflow suggestions isn't viable for the s48 as I haven't actually been hands on with one of those, for the most part I believe that the suggestions should work. I feel there is an element of having to be firm with the staff around you in terms of helping them understand the actual amount of work that goes into the technical side of theatre. Just accepting that plotting on the morning of a show is okay will not help ease your workload or stress. One thing that we are looking to implement this year is to build a visualisation of our space in Capture Visualisation software. I will then be taking phantom ZerOS into the rehearsal spaces when the pieces are nearing completion allowing me to spend more time programming the lighting requirements for each piece. When working with really tight schedules for things such as external lettings I will watch a piece and record colour, beam/shape and position palettes only on a main playback and use the other playbacks faders as intensity masters for different fixture groups. This way I can pull in and out various groups of lights whilst being confident that whatever I pull up will fit then overall look and style for the piece. Recording attributes this way will allow me to specifically make sure my front lights will always be a suitably white colour. I don't know if any of this is helpful but yeah, the main piece of advice would be to try and highlight that they are requesting too much from a solo technician and you deserve appropriate time on a day prior to the show day to set the tech.
Davidmk started following Busking Tips FLX S48 - Theatre
There's a lot to unpack in this, it certainly looks like there are unreasonable demands for one person and limited time so perhaps there need to be changes there and, if the time cannot be increased then either the demands must be reduced or they hire another tech. That said, there may be ways to simplify things but I'm not clear what your rig consists of and where things are located. Does the rig include moving heads? Could you reserve some fixtures for front-light that you can keep white? Do you have to plot everything for every piece or can some be pure busking? Can you impose some restrictions on what can be requested? e.g. Offering set colours rather than mixing to order, specific marked points on the stage for set pieces like solos/duets? Are you making use of palettes and intensity groups? When you record playbacks are you using tracking or not? (Full disclosure my background was in theatre - musicals/drama - but for the last 26yrs I've worked in a music venue almost exclusively pure busking for bands. I have zero knowledge about running sound.)
bootlace479 started following Busking Tips FLX S48 - Theatre
I work as the sole theatre technician in a performing arts college. For the shows, I run lighting and mics and backing tracks. Every year we run Showcase / variety shows, mostly Musical Theatre numbers, big group pieces to solos and everything in between, as well as some dance - Contemporary Solos and duets all the way to large group commercial pieces. I put each piece onto it's own playback, because often orders change last minute, or if we do multiple nights, not every piece is in every night. There are also some band nights, with the music course putting stuff on. We have an S48, and a rig of 36 colour change LED fixtures. The issue I have, is that as each year goes by, we get more students, and less time in our theatre space. I have gone to THE TOP to complain about less time, and there is nothing I can do to extend this. This means we're often teching on the morning of the show, which involves lighting every piece and running a mic plot (Thank god for theatremix). My workflow is fairly quick using groups i have preset, but I'm still struggling to get things done as quick as I'd like, as i find the recording of cues can be a bit clunky, and this is what takes the time. I'd like to get to a point I can busk my way through a piece recording cues as I go, and then run the piece again once cueing through it. I tried with having a bunch of set playbacks and using a combination of these with syntax, but I also found this a bit clunky - maybe its me! My main issue with the groups is I have set locations for each part of the stage, but sometimes I want some side colour and some front white, but the group selects all the fixtures here and would colour them the same, meaning i have to then go and select the fronts and recolour them... I know a certain amount of this comes down to how fast I am able to work, but I'm wondering if anyone has any tips for this with this desk? I have unlimited time with the desk, but not unlimited time with the pieces, so I can configure the desk any way i want with a view to getting things moving quickly when in the space with the company.
bootlace479 joined the community
CestM0i64 started following Pknight Art-Net ecosystem quality/reliability
Davidmk started following Solution desk servicing
You might find spares here if you ring them https://ultralightsound.co.uk/
Archie D started following New Zeros s/w and Solution not loading beyond 'Loading please wait...'
Archie D replied to Worcester RGSTech's topic in Solution & Solution XL
Hi @Worcester RGSTech, I've sent you an email that may help. Kind regards -
Has anyone got any experience with the Pknight Art-Net ecosystem? Their CR011R and CR021R prices seem too good to be true when comparing to similar devices listed on stage depot or Thomann. Their website feels like their products are technically sound and both devices seem to be opto-isolated which feels like a good sign. https://www.pknightpro.com/products/pknight-bi-directional-artnet-controller-cr011r https://www.pknightpro.com/products/pknight-artnet2-cr021 There is a comment in a review about it being incompatible with the FLX S24. Although I'm not planning on using it to convert DMX to Art-Net and (as the comment is of limited detail) I suspect is user error here seemed a reasonable place to see whether anyone has any experience using one. My own use will be to fire DMX signals from QLAB
John C joined the community
Raymond B. joined the community
Hi @DALX, Yes, Brian has already kindly sent the manual, but for future reference you can find it on the ZerOS Software page inside the Fixture Tools 2.6 ZIP download as a PDF. Here is a direct download link to that ZIP file. Fixture Tools is the general package that Zero 88 released, whereas Fixture Type Editor is an individual application within that package used to create/edit .ift files and export to .ift or .uft formats. Fixture Tools also includes the Common Fixture Manager application for the original Frog Range. Hope this helps! -
Is there a manual for Fixture Tools please ? Is Fixture Tools a rename of Fixture Type Editor ? I want to add gobo selection and images to a moving head spot thanks. -
Information for users (if anyone still cares!). I recently purchased (2nd hand) two Chilli Jr dimmers for an install at a local voluntary art space. As is my usual approach, I always inspect, refurbish and electrically test equipment before I deploy it. On one of the Chilli Jr dimmers I purchased I observed an unusually high earth leakage current compared to the other Chilli Jr dimmer, when testing with my Megger PAT tester. Around 5mA compared to the <1mA observed on the other (#2) Chilli Jr dimmer. I've tracked this down to the fitting of incorrect EMI capacitors at some locations on the phase trigger PCB. There is no evidence of any rework or repair on this board, so this looks like a factory pick/assembly error. These capacitors are used (correctly) elsewhere on the same PCB. The phase trigger board takes the three mains phases (or three copies of single phase mains) and derives the zero-crossing trigger signals for the triacs. For EMI purposes, there are X2 and Y2 capacitors employed across the line, neutral and earth supply terminals. - X2 capacitors are used line-neutral and fail short to trigger over-current protective devices. - Y2 capacitors are used line-earth and neutral-earth and fail open circuit to avoid creating a shock hazard on the metal casing (since these dimmers are Class 1 devices). I've found X2 class capacitors fitted where Y2 class capacitors should be fitted in one of the Chilli Jr dimmers. Photos show 0.1uF (100nF) X2 EMI capacitors fitted where 0.01uF (10nF) Y2 EMI capacitors should be fitted. As can be seen in the following photos, the X2 capacitors are grey, the Y2 capacitors are blue. Incorrect X2 (grey) caps fitted N-E on all three phases. Correct Y2 (blue) caps fitted L-E on all three phases. Correct X2 (grey) caps fitted L-N on phases 2 and 3 (phase 1 has transformer isolation). This is confirmed by observing in the Chilli Jr dimmer #2 the correct components fitted in these locations - blue Y2 caps. Correct Y2 (blue) caps are used correctly N-E and L-E. Correct X2 (grey) caps are fitted L-N on phases 2 and 3. On Chilli Jr #1 I'm replacing the three incorrect X2 N-E caps with TDK Y2 caps of the correct value (10nF) and lead pitch (15mm). Users beware.
- 1 reply
- 2
