Simonkbike Posted May 7 Report Posted May 7 Is @iank99 still around and servicing Zero88 desks? I have a Solution desk that needs some tlc - sticky faders, unreliable wheels. If not, are there any up-to-date recommendations for who to contact? Cheers, Simon Quote
kgallen Posted May 7 Report Posted May 7 I’m sorry, Ian unexpectedly passed away a couple of years back. I think your only call is someone like White Light (who I believe had his spares stock). Quote
Simonkbike Posted May 7 Author Report Posted May 7 Ah, sad news I must have missed. I'll try White light. Thanks S. Quote
Archie D Posted May 8 Report Posted May 8 On 5/7/2026 at 9:05 AM, Simonkbike said: Solution desk that needs some tlc - sticky faders, unreliable wheels. Hi Simon, It is extremely unfortunate that Ian passed away, he is definitely missed. Regarding the wheels - there is a tiny PCB on each wheel held by four plastic clips (two latch over the PCB and two stick up through holes on the PCB). If this PCB comes out of those clips and slides out slightly, the contacts don't meet the wheel and so the wheel's movements are not read correctly. If you don't get anywhere with White Light as kgallen has suggested, and are confident with opening your Solution up (the front panel along with the palm-rest hinges up from the base to an extent) then it may be worth checking those PCBs. If all PCBs are seated correctly and the wheels still do not respond correctly, it would be worth looking into spares. Hope this helps. Quote Archie - Student Student of lighting design & operation Owner of: Phantom ZerOS Unlock Dongle, SolutionXL, Frog 2, JesterML, Jester ML24, Juggler (x3), Level 6, Level 6 DMX, Level 12, Level 18 Plus, Sirius 24 (x2) & 48 (x2), Sirius 500, Lightmaster XLS (x2), Lightmaster 1200 (MK1), Frog, Fat Frog, Diablo, Orion, Alphapack 2, LS6 Dimmer (1981), 4x Zero 88 Focus 650 Fresnels, 2x Zero 88 Focus 650 Floods, 4x Zero 88 Focus 650 Pebble Convex's, Linebacker, Demux 48 (x2), Strand LX
Simonkbike Posted May 8 Author Report Posted May 8 Many thanks Archie, I'm happy to have a go but my committee are a bit less enthusiastic. I tried White Light but had trouble creating an account. I confirmed my email but get a never-ending spinny circle when I log in. Will try again next week but you've given me a backup at least. Quote
Davidmk Posted September 29 Report Posted September 29 You might find spares here if you ring them https://ultralightsound.co.uk/ Quote 2 x FLX with Raspberry Pi's running TouchOSC, ZerOS Wing, Leapfrog, Jester M24L Eurolite ArtNet/sACN nodes. ChamSys MagicQ compact connect with MagicQ/PC. Avolites T3 with Titan on PC. Regular tech in two Milton Keynes music venues plus occasional festival work.
