  1. Today
  2. Thanks, Archie. I'll do it when the existing production finishes. Dave
  3. There's your starting point, sounds like absolutely the right way to go. To do it, you need to record a "standard" showfile with your tools in place (by which, I mainly mean palettes). When busking, you need to have a way to quickly build a "look" so what you need is an adequate (not excessive) set of component parts and build looks from those. Offer directors a choice of from your palettes, no deviations except that will need some fixed, and marked, positions on the stage for your moving heads and some of those may vary from show to show. Get these up front and record the palettes. I'm afraid I can't tell you much about using intensity groups as I've never used them but look them up as they might be useful. Essentially, when you record a fixture group, you can record intensities with it. You will need a chase on a playback. Use global tap-tempo, two steps, intensity only (split your lights into two groups one on, the other off in each step) playback master set with intensity as LTP). When setting up the show choose two colours, record these in the cue and add a link to run the chase. One chase with two steps should be enough but you could make 3 step and 4 step ones as well if you really want to. You can make FX palettes but a better way might be to make some playbacks with your FX in and call them from your cues. You'll need a slow circle, a quick figure 8 and maybe a couple more. Again. No tuning of position, speed or anything during the run through. I could go on but I guess you have the picture by now. Having built your tool box, use it during the run through to build looks in the programmer and record them as cues. I'd suggest a setting a default time of 2s for everything and try not to deviate from it. Look at how you record, you might want tracking off, you might want to record snapshots or selected fixtures only - whatever you do, be consistent about it so you know where you are. If performances use backing tracks then you can set cues to run a fixed time after the previous cue, that way you only need to press go at the start of the track. This is fiddly to do and would have to happen between run through but it would de-stress actual performance a little bit. There's a lot to think about there, you may need to refer to the manual or training videos. I don't have time to put links in here but if you can't find something get back (DM if necessary) and I'll point you in the right direction. If you are near or in Milton Keynes we could meet in person if that helps.
  4. Yesterday
  5. Hi @simzee47, Each of the ZerOS software updates are independent from each other, as they contain the operating system and software bundled together in one package. You can go straight to ZerOS 8.0.1 without any worries. Archie
  6. Hi All, I've downloaded 8.0.0 but not installed yet as the desk has been in use a lot. Do I need to install 8.0.0 first and then download 8.0.1 and install or just do 8.0.1
  7. Last week
  8. Hello and welcome! I’m not sure if you’re the chap I replied to on Reddit. If not, do you also know about all of the training videos? There are some buttons at the top of the forum somewhere ^^^^
  9. Good points, I was trying to keep it short, but realising my situation is sort of unique. Unfortunately, there is little option to recruit extras, or reduce the demands. Working in a college, which runs all sorts of A levels. It's in financial crisis, and generally other courses are struggling. The Performing Arts course numbers, results and progression onto conservatoires and university's is absolutely through the roof, which is great. We have our own building, with lots of studios, so kind of get left alone, but unfortunately our main 'theatre space' is a multi use hall. More and more people are booking said hall for stuff so we get less time in it. Myself and all teachers have raised this and we get shot down, so we are where we are. I have a 10 x 10 Harlequin dancefloor, with 4 bars above. 3 bars above the dance floor, 1 bar above the audience area - these are the front facing, 4 fresnels. The three bars above cover rear middle and front of the 10x10 floor, and booms at the bottom of these 3 bars. My group pallettes are arranged by stage location, stage split into 6 separate areas - USR, CSR and DSR and the same for SL. 4 moving head profiles, located at each corner of the 10x10 floor. Fresnels and Pars on booms. a couple of pars thrown up top for washes. Not ideal but it's what we've got. I COULD, but i often get asked for cool white vs warm white depending on the piece, or red front for example. If i locked the fronts to white, i'd lose that. That is something to think about. Has to be plotted, as during the show I'm running mics, and just have to press go on the lighting - which i manage with clever script marking. We have a few profiles that are in set locations that get used for solos and duets, and these work and are restaged. It's mainly the larger group pieces that are heavily choreographed - usually big show numbers from different musicals. I will tend to try and design based on that musical. Palettes yes, but Intensity group? Are you referring to the ICPBCSE (??) snapshot type thing? I believe SmartTag > Cue Only is set, at least this is how the S24 in our small blackbox is set - as the only lighting tech, I don't see why I'd have set them differently. Can't get in the hall till next week to confirm sadly. Happy to hear from someone else in similar position... I'm also the set designer, builder, painter, maintenance guy... can you relate? I have been looking into Capture, and actually we've unlocked a small funding stream this year that may mean we can actually access that. This would actually ease things up massively, as the tech days could become tidy things up. The worst bit is, the actual team i work with, the teachers and people who choreograph and teach the singing are on my side, they help limit cues and manage student expectation as much as possible, but those managers above us have no idea what we do, or what we even mean by tech days. a couple years ago we had tech weeks, but this year we have literally only got two days available, so it's really cramming everything in! If you can, could you unpack what you mean by recording colour and beam and position onto playbacks and intensity on others? Maybe this is FLX specific, but I want to explore slightly, as mixing faders sounds like what i'm looking for. My idea is to busk the piece the first time I'm seeing it, and record the bits i like as I'm doing that, then run the piece a second time with those recorded cues and just tweak from there, and so far I've not worked out a comfortable way of doing this.
  10. I am also a Theatre Tech for a College and can sympathise with your situation. I'm working with the full size FLX so apologies if some of my workflow suggestions isn't viable for the s48 as I haven't actually been hands on with one of those, for the most part I believe that the suggestions should work. I feel there is an element of having to be firm with the staff around you in terms of helping them understand the actual amount of work that goes into the technical side of theatre. Just accepting that plotting on the morning of a show is okay will not help ease your workload or stress. One thing that we are looking to implement this year is to build a visualisation of our space in Capture Visualisation software. I will then be taking phantom ZerOS into the rehearsal spaces when the pieces are nearing completion allowing me to spend more time programming the lighting requirements for each piece. When working with really tight schedules for things such as external lettings I will watch a piece and record colour, beam/shape and position palettes only on a main playback and use the other playbacks faders as intensity masters for different fixture groups. This way I can pull in and out various groups of lights whilst being confident that whatever I pull up will fit then overall look and style for the piece. Recording attributes this way will allow me to specifically make sure my front lights will always be a suitably white colour. I don't know if any of this is helpful but yeah, the main piece of advice would be to try and highlight that they are requesting too much from a solo technician and you deserve appropriate time on a day prior to the show day to set the tech.
  11. There's a lot to unpack in this, it certainly looks like there are unreasonable demands for one person and limited time so perhaps there need to be changes there and, if the time cannot be increased then either the demands must be reduced or they hire another tech. That said, there may be ways to simplify things but I'm not clear what your rig consists of and where things are located. Does the rig include moving heads? Could you reserve some fixtures for front-light that you can keep white? Do you have to plot everything for every piece or can some be pure busking? Can you impose some restrictions on what can be requested? e.g. Offering set colours rather than mixing to order, specific marked points on the stage for set pieces like solos/duets? Are you making use of palettes and intensity groups? When you record playbacks are you using tracking or not? (Full disclosure my background was in theatre - musicals/drama - but for the last 26yrs I've worked in a music venue almost exclusively pure busking for bands. I have zero knowledge about running sound.)
  12. I work as the sole theatre technician in a performing arts college. For the shows, I run lighting and mics and backing tracks. Every year we run Showcase / variety shows, mostly Musical Theatre numbers, big group pieces to solos and everything in between, as well as some dance - Contemporary Solos and duets all the way to large group commercial pieces. I put each piece onto it's own playback, because often orders change last minute, or if we do multiple nights, not every piece is in every night. There are also some band nights, with the music course putting stuff on. We have an S48, and a rig of 36 colour change LED fixtures. The issue I have, is that as each year goes by, we get more students, and less time in our theatre space. I have gone to THE TOP to complain about less time, and there is nothing I can do to extend this. This means we're often teching on the morning of the show, which involves lighting every piece and running a mic plot (Thank god for theatremix). My workflow is fairly quick using groups i have preset, but I'm still struggling to get things done as quick as I'd like, as i find the recording of cues can be a bit clunky, and this is what takes the time. I'd like to get to a point I can busk my way through a piece recording cues as I go, and then run the piece again once cueing through it. I tried with having a bunch of set playbacks and using a combination of these with syntax, but I also found this a bit clunky - maybe its me! My main issue with the groups is I have set locations for each part of the stage, but sometimes I want some side colour and some front white, but the group selects all the fixtures here and would colour them the same, meaning i have to then go and select the fronts and recolour them... I know a certain amount of this comes down to how fast I am able to work, but I'm wondering if anyone has any tips for this with this desk? I have unlimited time with the desk, but not unlimited time with the pieces, so I can configure the desk any way i want with a view to getting things moving quickly when in the space with the company.
  13. Earlier
  14. You might find spares here if you ring them https://ultralightsound.co.uk/
  15. Hi @Worcester RGSTech, I've sent you an email that may help. Kind regards
  16. Our Solution has decided that it is not going to start beyond showing 'Loading, please wait...' following changing the CR2032 coin cell battery. Any ideas on the forum? Thank you.Simon IMG_2693.MOV
  17. Has anyone got any experience with the Pknight Art-Net ecosystem? Their CR011R and CR021R prices seem too good to be true when comparing to similar devices listed on stage depot or Thomann. Their website feels like their products are technically sound and both devices seem to be opto-isolated which feels like a good sign. https://www.pknightpro.com/products/pknight-bi-directional-artnet-controller-cr011r https://www.pknightpro.com/products/pknight-artnet2-cr021 There is a comment in a review about it being incompatible with the FLX S24. Although I'm not planning on using it to convert DMX to Art-Net and (as the comment is of limited detail) I suspect is user error here seemed a reasonable place to see whether anyone has any experience using one. My own use will be to fire DMX signals from QLAB
  18. Hi @DALX, Yes, Brian has already kindly sent the manual, but for future reference you can find it on the ZerOS Software page inside the Fixture Tools 2.6 ZIP download as a PDF. Here is a direct download link to that ZIP file. Fixture Tools is the general package that Zero 88 released, whereas Fixture Type Editor is an individual application within that package used to create/edit .ift files and export to .ift or .uft formats. Fixture Tools also includes the Common Fixture Manager application for the original Frog Range. Hope this helps!
  19. Thanks Brian, thats what I was looking for.
  20. Found this a while back, can't remember where. It only mentions the legacy desks but that's when this software dates back to. Fixture Editor User Guide_260902_181930.pdf
  21. Is there a manual for Fixture Tools please ? Is Fixture Tools a rename of Fixture Type Editor ? I want to add gobo selection and images to a moving head spot thanks.
  22. Hi @alg, ZerOS 8.0.0 contained minor bugs that could crash consoles, but this has been resolved with ZerOS 8.0.1 and user feedback has been generally positive about this bugfix from what I've seen. The CRDOWNLOAD file you see is a general file that is put in place for a file that is currently being downloaded or paused and hasn't finished downloading. This is normal to see while a file is downloading. You can try downloading Phantom ZerOS 8.0.1 again here from the ZerOS Software page. I hope this helps.
  23. I have just discovered that there is a new Zeros 8.0.1 update. There seemed to be a number of generally negative comments about this. What is the position on this new version? Is it worth it. I have tried to run the Phantom version to test it but it only seems to download a file version CRDOWLOAD File, Microsoft wont open this. Any suggestions?
  24. Replaced the 3 incorrect caps. Tested ok. Earth leakage now <1mA as expected.
  25. Information for users (if anyone still cares!). I recently purchased (2nd hand) two Chilli Jr dimmers for an install at a local voluntary art space. As is my usual approach, I always inspect, refurbish and electrically test equipment before I deploy it. On one of the Chilli Jr dimmers I purchased I observed an unusually high earth leakage current compared to the other Chilli Jr dimmer, when testing with my Megger PAT tester. Around 5mA compared to the <1mA observed on the other (#2) Chilli Jr dimmer. I've tracked this down to the fitting of incorrect EMI capacitors at some locations on the phase trigger PCB. There is no evidence of any rework or repair on this board, so this looks like a factory pick/assembly error. These capacitors are used (correctly) elsewhere on the same PCB. The phase trigger board takes the three mains phases (or three copies of single phase mains) and derives the zero-crossing trigger signals for the triacs. For EMI purposes, there are X2 and Y2 capacitors employed across the line, neutral and earth supply terminals. - X2 capacitors are used line-neutral and fail short to trigger over-current protective devices. - Y2 capacitors are used line-earth and neutral-earth and fail open circuit to avoid creating a shock hazard on the metal casing (since these dimmers are Class 1 devices). I've found X2 class capacitors fitted where Y2 class capacitors should be fitted in one of the Chilli Jr dimmers. Photos show 0.1uF (100nF) X2 EMI capacitors fitted where 0.01uF (10nF) Y2 EMI capacitors should be fitted. As can be seen in the following photos, the X2 capacitors are grey, the Y2 capacitors are blue. Incorrect X2 (grey) caps fitted N-E on all three phases. Correct Y2 (blue) caps fitted L-E on all three phases. Correct X2 (grey) caps fitted L-N on phases 2 and 3 (phase 1 has transformer isolation). This is confirmed by observing in the Chilli Jr dimmer #2 the correct components fitted in these locations - blue Y2 caps. Correct Y2 (blue) caps are used correctly N-E and L-E. Correct X2 (grey) caps are fitted L-N on phases 2 and 3. On Chilli Jr #1 I'm replacing the three incorrect X2 N-E caps with TDK Y2 caps of the correct value (10nF) and lead pitch (15mm). Users beware.
  26. Thanks for looking. My desk is at a school so tried it with Phantom ZerOS without success, will try it on the desk tomorrow.
  27. Hi Rye, Great to hear you were able to get it working. Correct, fixtures that have red text in the Fixture Schedule are non-library fixtures. Yes, the on-board Fixture Creator & Editor within ZerOS allows for longer parameter names than Fixture Tools does. This is because Fixture Tools supports legacy desks (such as the Frog Range, Jester Range, Illusion 500 etc.) which only supported a certain amount of characters for parameter names. The ZerOS Fixture Editor allows for longer names because it doesn't have to contain compatibility for legacy desks which hold that limitation. Fixture Tools only supports loading .ift files and not .zfix files. This means that zfix files cannot be loaded into Fixture Tools to be edited, and can only be modified on the desk. One of the reasons of that is zfix files can contain multicell information, and Fixture Tools does not support multicell functionality. However, once you load in a .ift fixture file into the desk (SETUP -> Load), you can actually edit it in the ZerOS Fixture Editor from Add Fixtures. Beware though, making any edits to anything in that fixture personality within ZerOS will remove all parameter detail information you have added from Fixture Tools as it writes new parameter information when you re-save the file (in the zfix format this time), so lengthening parameter names once loaded into ZerOS isn't possible. I would only recommend doing so if you don't have any parameter detail information in that profile that is important. I hope this helps, let me know if you have any questions.
  28. Thanks Archie It took a bit of experimenting, trial and error and then a while inputting all of the details but I was able to get it all working. The fixture is showing up Red in the Fixture Schedule - which I assume is because it's a non-library fixture The only very minor gripe I had was the Fixture Editor only let me have parameter names with a max of 7 characters, so I had to shorten the parameter names - but not actually a big deal. I didn't end up needing to - but is there a way to like, export an existing fixture from the desk to then edit in the Fixture Editor? I tried to do something like that, but since the desk exports as .zfix files and the Editor only uses .ift I'm guessing you can't edit an existing fixture, so you'd have to create a new one from scratch, which is what I did
  29. Hi @DALX, Slight query - I can't seem to replicate your copying procedure using syntax. Typing the syntax to copy cue 1 on playback 1 to cues 5, 10, 15, 20 gives invalid syntax at the second period (1/1 Copy To 5.10. <-) as only one decimal point is allowed. This means cue 1 can only be copied to cue 5.1, disallowing the period to be used as a separator. Alternatively, using the copy window (Z/Shift -> Copy).. From 1 To 5.10.15.20 returns a new cue numbered 5.1. ZerOS is interpreting my entry as a point cue here too rather than multiple cue numbers, given that point cue numbers can only be up to 2 decimal places. The second period invalidates the further numbers anyway. In ZerOS, you can copy multiple cues to a single cue number. That single cue number acts as the starting number. For example, copying cues 1>5 to cue 10 will create cues 10 to 15. Copying cues 1+3+5 to cue 30 will create cues 30, 31 and 32. In the Copy Window, only the 'From' input box allows + and > whereas the 'To' input box doesn't. Please could you elaborate further on what you're doing to achieve this? I might be missing something. Many thanks
