Edward Z88
  1. Hi Rigo, The Reset DMX Outputs option in Setup will temporarily reset the DMX outputs for a few seconds, and then return the output to the previous values. More information can be found in the manual here... http://support.zero88.com/975242041 You therefore should be able to use the console as normal without loosing show data or requiring a software update. If you have tried doing this and experienced issues, try power cycling the console. Hope this helps, Edward
  2. Hi Romec, When macros have been programmed, they can't be edited. When you recall a macro, you will see the commands being typed in the command line. If you wish you can slow the playback speed. To do this hold SETUP and tap the Macro tile in the macros window, and from the Speed drop down choose Slow. Macros can include as many button presses as you wish. If you wanted this to be a macro, you would tap RECORD -> MACRO -> 1 -> Commands -> [fixture number] -> [attribute key followed by palette number] -> RECORD -> [attribute key followed by palette number you wish to overwrite] -> ENTER -> MACRO. Edward
  3. Hello, If you turn the console on, tap Z/Shift -> System Information, is the software still displaying ZerOS 7.9.4.3? Edward
  4. Hi Romec, When recording a macro, you have the option to record keys, or commands. If you choose commands, anything that gets written in the command line will be stored, until you press the MACRO button. Then when you recall the macro, all commands will be replayed as a single string. Hope this helps, Edward
  5. Hi Olly, OK thanks for confirming. Yes keep me updated on the return - feel free to email if you wish. Will let you know what the issue is. Again really sorry you've experienced this fault, if there's anything we can do let me know. Edward
  6. Hello, OK thanks for the information. This sounds like it could be an intermittent power issue, however we haven't seen anything like this before. If you have any questions feel free to drop me an email or give us a call. Edward
  7. Hi Olly, Really sorry to hear this. I believe you have spoken to Keith on the phone regarding this. So to confirm, you have created a bootable USB drive with ZerOS 7.9.5. Booting the console boots into the install screen, where you can perform the installation. When complete, power cycle, and the console sometimes boots correctly? Please try repeating this process, however with ZerOS 7.9.4, available here... If this still hasn't solved the problem, please go back to Hawthorn, who if necessary will be able to send it back to us for investigation. The battery shouldn't have anything to do with the issue. Feel free to continue the conversation over email if that's easier. Kind regards Edward
  8. Hello, Many thanks for the information regarding the FERAM Write failure. We will take a look into this. I am not sure why your console isn't displaying the U-boot or Q7 information, which in that picture should be lines of text between "Co-Processor Firmware" and "NVR Location". However as your picture shows the serial number I can get this information from there. I have added this to our issue log, as reference number ZOS-8639. If you have any queries let me know. Edward
  9. Hi Hendrik, Sorry to hear this - are you experiencing these issues running ZerOS 7.9.5? All the best, Edward
  10. Hi Step, On FLX, cues can be triggered by the Go button, the previous cue, the real time clock, or MIDI. For more information on MIDI triggers, see below... http://support.zero88.com/990063141 BPM speeds can be configured for any chase, or a global BPM can be used. For more information on Global BPM, see the article below... http://support.zero88.com/1011580981 Hope this helps, Edward
  11. Morning, Hmm interesting. I presume after power cycling there was no offer to save a debug file? If you tap Z -> System Information -> System Text, and scroll through the text, are there any error messages/ text that isn't white? If you then tap back to Desk Info, there's a line of text starting with "Q7", and after a "PN", there should be "HW:B_". What is the number here? Kind regards, Edward
  12. Hi Jolyon, Good to hear you have a FLX S48 for your theatre. The console name in System Settings by default simply lists the console's serial number. You can however change this name to something more useful if you wish. This name is what the console appears as over a network. You can find your current software version by tapping Z/Shift -> System Information, and in this window will be a line of text displaying "Software Version". Judging by the serial number of the console, you are probably running ZerOS 7.9.4.3. The latest software is ZerOS 7.9.5. As you are learning the console, I would recommend updating to the new software. ZerOS 7.9.5 is available to download from our website here... Once downloaded, extract the files, and then copy the ZerOS OS Creator application to the root of a USB stick. Plug into the console, tap SETUP -> Load File, and choose the file to load in. The console will then ask you to confirm, and begin the installation. More detailed instructions are available in the release notes, which can also be downloaded from the link. An easy way of seeing what fixtures your faders are controlling, is to view the Faders desktop - particularly useful if you have an external monitor connected. This will show you what your faders are doing - which page and which function. Hope this helps, if you have any questions just let us know. Edward
  13. Hi Martin, Thanks for the information, have added them to the list. Edward
  14. Hi Benjamin, You can change your user name to be your email address if you wish? Edward
  15. Hi Benjamin, I believe SmartTag will be the cause of the first issue. Let us know how you get on. Edward
  16. Hi Tim, Sorry to hear this. Is there a DMX indicator on the dimmers/ splitter? Does this go off/display no DMX when this happens? Is there any correlation to the times it happens - for example is there something specific you are doing on the console when it happens? How often does this seem to occur? Are you able to send us your show file the issue is present in? If so please send this to support@zero88.com, with a link to this forum thread. Kind regards, Edward
  17. Hi Stepan, Effect speed can't currently be controlled by BPM. Chases however can be assigned a BPM tempo. All the best, Edward
  18. Hi Jamie, What software are you currently running on your LeapFrog? ZerOS 7.9.5 is the latest software, and can be downloaded here... Release notes are also available to download from the same link, with installation instructions. Hope this helps, Edward
  19. Hi Matthew, If the console recalls the previous fader function on boot, there is no need for the option in Setup. The option planned for Setup was only going to be a "Boot option", and therefore when booted the user could still change the fader function if they wished. I appreciate, the ideal situation for your implementation would be to have a locked down "operator mode", where only faders can be operated from the iPad. When the console is locked, playbacks can be operated using the faders, however not via the remote. If you have any queries let me know. Edward
  20. Hi Peter, As mentioned in the thread you linked to, the new effects aren’t loaded, if software is installed from a bootable USB drive, rather than running the install application on the console. I haven’t seen this before. So when FLX displayed switch off the console, how long did you leave after turning the console off and on again? How long did you wait whilst the page segment display was loading? Did you see anything on the internal or external screens? All the best, Edward
  21. Hi Benjamin, Did you swap your original fixture to your edited fixture? If so did you power cycle the console before exiting Setup? Changes made in setup are not stored until you exit setup, which may be why you changed the fixture, power cycled, and the old one was back again. There is no way of deleting fixtures from the library on the console. As Kevin says, when loading in fixture profiles make sure they are named differently to those already in the library, otherwise you won’t be able to tell the difference between the two. Hope this helps, Edward
  22. Hi Matthew, Rather than having an option in Setup, instead FLX S consoles will now remember the fader function they were in before power off. You should therefore find if you change to playbacks, power cycle, the console will boot back up in playbacks. You can see this process happening, as now when you tap the fader function button, the save icon temporarily goes red, as that change is stored on the console. Hope this helps, let me know if you have any questions. Edward
  23. Hi Ethan, When you press "Automatically Create Macros", these are Fixture Macros, which are generated from the currently patched fixtures. However, Macros can also be programmed, to save you button presses on the console. For example, you might program a macro that selects some fixtures, and takes you straight to the colour MFKs. This would be programmed by using the following command: RECORD -> MACRO -> choose an empty Macro MFK -> Choose to record either keys, or the command line -> select your fixtures -> COLOUR -> MACRO. The macro is now stored, and now when you press this macro palette, the fixtures will be selected and colour will display on the MFKs. Macros can then be triggered by cues, meaning you could simply record a macro of the Playbacks page button being pressed, and then have this triggered by a cue in the cue stack when you need to access the next playback page. If you have any queries let me know. Edward
  24. Hello, No problem! Yes, the shortcut for Highlight is SHIFT + HOME. Pressing the CLEAR button once will always clear any fixture selections, and a second press will clear any programmer data. If however you only want to clear the programmer of specific fixtures, you can use the Clear Fixture function. To access this function hold SETUP and tap INSERT. Using the drop-down menu, choose Clear Fixture. Now, pressing INSERT will clear the programmer of the currently selected fixtures. To do this hold SETUP and tap an empty playback. From the options choose Speed Override, and click OK. This fader will now also control Speed Override, as well as the pot next to the Master Playback. If you tap SUBMASTERS, the external monitor will show you the fader's functionality. Hope this helps, let us know if you have any other questions. Edward
  25. Hello, ENTTEC Wings are no longer supported by ZerOS. You will therefore have to run an old software version on your FLX to be able to use them. What software version are you running on your FLX? You can find out by tapping Z -> System Information. If you are on an older version, you will be able to connect your wing, FLX, and other network devices into an ethernet switch. You can then tap SETUP -> Wings on FLX, and ensure FLX is also set to receive a DHCP IP address if the wings are also configured that way. Kind regards, Edward
