kgallen Posted December 17, 2023 Report Share Posted December 17, 2023 Not urgent (as in a few days will be fine!). (Simplified scenario to get to the nub of how I program this requirement). Basically I want to be able to highlight some panto business at a stage position with a special (channel 3) but I want to check back the general cover in that area (channels 1 and 2). Let's say channels 1 and 2 (plus others) are part of the general cover and are on stage and bright, say 90%, and they are sourced from a cue stack running on the main playback. I'll be Tracking on. I want to program another manually-applied playback, say PB1, where I want the playback fader to take channel 3 (the special) up to full but also to take channels 1 and 2 down to (say) 50%. All intensities would be proportional to PB1 fader. If the PB1 fader is reduced to zero, I want the controlled channels (1,2,3) to release back to main playback control. If I use this PB1 when channels 1 and 2 are currently at 0%, then I want them to stay at 0%, not come on! How would I program this? Is this a use of Inhibit (for channels 1 and 2). Maybe I program PB1 with 1@@, 2 AND 3@50 and then Setup PB1 as Inhibit with Release on Lower enabled. Do I need to do anything else (like set LTP?). When I run this on PB1 do I need to start pressing PB1 GO button or can I just use the fader (desired). Thanks! Quote Link to comment Share on other sites More sharing options...
kgallen Posted December 17, 2023 Author Report Share Posted December 17, 2023 I did this: 1@@, 2 AND 3@50 and had to set PB1 to Intensity Mixing = LTP, and it worked perfectly if ch1,2 are on (and above 50%). If ch1,2 are off then they come on at 50% which is not what I want... Setting to Inhibit didn't work at all as I expected. The PB1 fader was at 0 and the main cue was live (1,2@90). Raising PB1, it took ch1,2 to 45 (expected, this is 50% of the 90) but ch3 didn't come on at all, and when I dropped the fader, ch1,2 went out - did not release to the main playback. In the PB1 Raise and Lower, all of the Raise and Release settings were greyed out, so I couldn't disable Release on Lower. Probably this is all as expected to Edward, but clearly I'm not understanding Inhibit very well! Quote Link to comment Share on other sites More sharing options...
Davidmk Posted December 17, 2023 Report Share Posted December 17, 2023 2 hours ago, kgallen said: I want the playback fader to take channel 3 (the special) up to full but also to take channels 1 and 2 down to (say) 50% 1 hour ago, kgallen said: Setting to Inhibit didn't work at all as I expected Inhibit sets a top limit on intensity values - like a grandmaster that only applies to certain channels. I don't think you can use it to both reduce and increase intensities. Nearest I can suggest, using inhibit, is to record chs 1 & 2 @100% on PB3 and set that to inhibit and ch 3 on PB4 @100% put PB at full and leave it there until it is needed. When the business happens, reduce PB3 and increase PB4. It's either that or record a cue for the business and another to restore the state. 1 Quote Link to comment Share on other sites More sharing options...
Jon Hole Posted December 17, 2023 Report Share Posted December 17, 2023 7 hours ago, Davidmk said: like a grandmaster that only applies to certain channels. I don't think you can use it to both reduce and increase intensities. This is exactly right. Your suggestion of two playbacks is the only way I can think of doing this too - because the behaviour needs to change based on the status of Ch 1&2, making LTP not suitable. Quote Jon Hole Global Product Manager, Systems and Control Link to comment Share on other sites More sharing options...
Edward Z88 Posted December 18, 2023 Report Share Posted December 18, 2023 23 hours ago, kgallen said: Basically I want to be able to highlight some panto business at a stage position with a special (channel 3) but I want to check back the general cover in that area (channels 1 and 2). Let's say channels 1 and 2 (plus others) are part of the general cover and are on stage and bright, say 90%, and they are sourced from a cue stack running on the main playback. There have been occasions where I've needed to do this. In these situations, I raise my special playback, and simultaneously lower my Master Playback's fader, until I've got the balance how I want it. Is there a particular reason you don't want to touch the Master Playback in this situation? 22 hours ago, kgallen said: when I dropped the fader, ch1,2 went out - did not release to the main playback. In the PB1 Raise and Lower, all of the Raise and Release settings were greyed out, so I couldn't disable Release on Lower. 21 hours ago, Davidmk said: Inhibit sets a top limit on intensity values - like a grandmaster that only applies to certain channels As @Davidmk mentions, Inhibit is essentially a Grand Master for certain fixtures. You cannot "release" the Grand Master - it always governs the overall intensity output from the console. This is therefore the same behaviour of an inhibit playback - the Trigger On Raise & Release On Lower options are irrelevant, so are greyed out. Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
kgallen Posted December 18, 2023 Author Report Share Posted December 18, 2023 On 12/17/2023 at 1:24 PM, Davidmk said: Nearest I can suggest, using inhibit, is to record chs 1 & 2 @100% on PB3 and set that to inhibit and ch 3 on PB4 @100% put PB at full and leave it there until it is needed. When the business happens, reduce PB3 and increase PB4. Thanks @Davidmk and @Jon Hole I think as you suggest this is the most practical solution. 8 hours ago, Edward Z88 said: There have been occasions where I've needed to do this. In these situations, I raise my special playback, and simultaneously lower my Master Playback's fader, until I've got the balance how I want it. Is there a particular reason you don't want to touch the Master Playback in this situation? Hi @Edward Z88, thanks! Yea I've done this in the past, but in this instance it will be just part of the lighting state I want to check back, not the whole rig. I've watched the Inhibit video https://www.zero88.com/manuals/zeros/cues-playbacks/playback-settings/general a couple of times to clarify this function. Thanks all for your help! 🙂 Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted December 18, 2023 Report Share Posted December 18, 2023 12 minutes ago, kgallen said: but in this instance it will be just part of the lighting state I want to check back, not the whole rig. Ah yep, a dedicated Inhibit is the way to go then 👍🏼 1 Quote Edward Smith Product Specialist Email Support Link to comment Share on other sites More sharing options...
