AndyJM Posted March 26, 2022 Report Posted March 26, 2022 When recording a show on Master playback, it's really frustrating that with each new cue the display goes back to the start. So when I've just recorded LX50 and want to check it runs correctly from 48 onwards, I can't seem to just go back one or two cues but have to scroll the screen from right back at the beginning. Or am i missing something? Quote
Davidmk Posted March 26, 2022 Report Posted March 26, 2022 If all you are trying to do is to select the cue you wish to execute then this page in the manual might help. Quote 2 x FLX with Raspberry Pi's running TouchOSC, ZerOS Wing, Leapfrog, Jester M24L Eurolite ArtNet/sACN nodes. ChamSys MagicQ compact connect with MagicQ/PC Regular tech in two Milton Keynes music venues plus occasional festival work.
kgallen Posted March 26, 2022 Report Posted March 26, 2022 2 hours ago, AndyJM said: When recording a show on Master playback, it's really frustrating that with each new cue the display goes back to the start. So when I've just recorded LX50 and want to check it runs correctly from 48 onwards, I can't seem to just go back one or two cues but have to scroll the screen from right back at the beginning. I agree. I’ve been asking about this for some years. I have the same frustration when programming a sequential (theatre) stack. Quote
delfine Posted March 27, 2022 Report Posted March 27, 2022 Bonsoir, Tu peux assigner le bouton SHIFT +Flash en PAUSE. Alors si tu fais deux fois "pause", tu reviens en arrière. Mais peut-être que je n'ai pas compris ton problème Quote
Edward Z88 Posted March 28, 2022 Report Posted March 28, 2022 Hi @AndyJM On 3/26/2022 at 8:09 AM, AndyJM said: When recording a show on Master playback, it's really frustrating that with each new cue the display goes back to the start. So when I've just recorded LX50 and want to check it runs correctly from 48 onwards, I can't seem to just go back one or two cues but have to scroll the screen from right back at the beginning. Or am i missing something? When you go into the last cue of a playback, the "Next" cue will be cue 1, as playbacks will wrap around automatically. The Cues window is always "focussed" on the Next cue, and so you scroll to the top. On 3/26/2022 at 10:26 AM, kgallen said: I agree. I’ve been asking about this for some years. I have the same frustration when programming a sequential (theatre) stack. As per @kgallen's comment, we would like to review this behaviour. This is logged as reference number ZOS-8694 on our software tracking system. I have raised the priority of this issue following your request. 21 hours ago, delfine said: Tu peux assigner le bouton SHIFT +Flash en PAUSE. Alors si tu fais deux fois "pause", tu reviens en arrière. Mais peut-être que je n'ai pas compris ton problème On FLX consoles, a few taps of the Up arrow gets you back to the bottom of the Cue list. On FLX S consoles, you could use the Pause functionality as described by @delfine. Configuring the Master Playback's button's shifted function to pause, would allow you to hold Z/Shift and double tap Go, to get back to the bottom of the cue list. If you have any questions, please let us know. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
AndyJM Posted March 29, 2022 Author Report Posted March 29, 2022 Thanks . How do I configure the Master playback shift function?? Quote
Edward Z88 Posted March 29, 2022 Report Posted March 29, 2022 Hi Andy, 4 minutes ago, AndyJM said: Thanks . How do I configure the Master playback shift function?? Hold SETUP and tap your Master Playback's button. This will open the Playback's Settings. Hold the Z/Shift key, and then choose "Pause" from the button function options at the bottom. Then release the Z/Shift key, and you should see the option returns to "Go (Fade)". You can then click OK. Now when you hold Z/Shift and tap the Master Playback's go button, you will pause it. Please see the link below for more information... https://zero88.com/manuals/zeros/cues-playbacks/playback-settings/general#button Hope this helps, Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
