Uriahdemon Posted March 12, 2023 Report Share Posted March 12, 2023 Afternoon all. I have a bunch of movers and have recorded all the attributes (posn, colour, effects etc) on a number of cue stacks. What I would like to do is add and remove some fixtures (movers) so I have groups of them independent of others but can still use the attributes I have recorded on the cue stacks. I have tried updating a single cue by getting it to output selecting the group of fixtures I want to for this example remove, hit remove on the update options but no joy unfortunately. I also cannot fine anywhere to find and read about the 'Update Options' to fully understand what I can and cannot do with them. Thanks again in advance. Quote Link to comment Share on other sites More sharing options...
kgallen Posted March 12, 2023 Report Share Posted March 12, 2023 For Remove to work you have to tag every attribute of the fixture. So the approach is: - select fixtures to remove - HOME - Update with Remove As for your wider question I’m not quite sure I understand what you want to do (especially the bit about removing them!). Quote Link to comment Share on other sites More sharing options...
kgallen Posted March 12, 2023 Report Share Posted March 12, 2023 Manual is here and yes it’s even harder to find on Vari-lite site but it is the same URL as it was before if you have links in other threads https://www.zero88.com/manuals/zeros?filter=3 The trouble with the manual is it’s more of a ‘reference manual’ than a ‘user manual’ since it’s laid out command for command rather than ‘I want to do this’. If you know what you want AND you know it exists then it’s findable with persistence. I wish the search prioritised commands in the results. If you search ‘remove’ or ‘update’, which are fairly generic words, then you get many pages of results and the early results are probably not what you’re looking for… gripe over (for now!). Quote Link to comment Share on other sites More sharing options...
kgallen Posted March 12, 2023 Report Share Posted March 12, 2023 This video? https://youtu.be/--EeATsqH-o Quote Link to comment Share on other sites More sharing options...
Uriahdemon Posted March 12, 2023 Author Report Share Posted March 12, 2023 Thanks Kevin, worked a treat and will have a read up on the links a little later. Much appreciated !! Quote Link to comment Share on other sites More sharing options...
Edward Z88 Posted March 14, 2023 Report Share Posted March 14, 2023 On 3/12/2023 at 6:20 PM, Uriahdemon said: Thanks Kevin, worked a treat and will have a read up on the links a little later. Much appreciated !! For information on removing fixtures from cues, please see the link below... https://www.zero88.com/manuals/zeros/cues-playbacks/updating-cues/update-options#remove Edward 1 Quote Edward Smith Product Specialist Link to comment Share on other sites More sharing options...
