beyond the blue Posted September 8, 2023 Report Posted September 8, 2023 Is there anyway to fast forward and pause a long fade (15 minutes) to see the lighting state at say 10 minutes into the fade before recording it? FLX S48 with external monitor. Quote
Davidmk Posted September 8, 2023 Report Posted September 8, 2023 Could speed override (see manual here) help? There's also Pause, here. Quote 2 x FLX with Raspberry Pi's running TouchOSC, ZerOS Wing, Leapfrog, Jester M24L Eurolite ArtNet/sACN nodes. ChamSys MagicQ compact connect with MagicQ/PC Regular tech in two Milton Keynes music venues plus occasional festival work.
Edward Z88 Posted September 11, 2023 Report Posted September 11, 2023 Hi @beyond the blue On 9/8/2023 at 5:56 PM, beyond the blue said: Is there anyway to fast forward and pause a long fade (15 minutes) to see the lighting state at say 10 minutes into the fade before recording it? You wouldn't be able to preview this transition prior to recording the cue. I would recommend recording the cue, and then as per @Davidmk's suggestion, you could use Speed Override to "fast forward" the transition, and then pause it. The fade progress bars are displayed at the bottom of the Cues window. If you then needed to tweak the cue you've just recorded, allow the cue transition to complete, and then edit and update it. As well as using the Speed Override encoder, you can configure a Speed Override playback fader. Please see the link below... https://www.zero88.com/manuals/zeros/cues-playbacks/special-playback-functions Hope this helps. Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
