Afx Posted September 22, 2019 Report Posted September 22, 2019 Fades on flash exec-screen scalable custom window that you can build by yourself from whatever you want pixmap, I take it that this is on works? oneshot fx option fx options improvements, show phase and add the option to expand the top/bottom of the waves General update on looks from 90´s :P Add yours for the dev team to look at. Also, if possible, z88-team could notify on how things are going :) Quote
Davidmk Posted September 22, 2019 Report Posted September 22, 2019 In order of priority (to me)... High - Faders screen able to display any playback page, not just the one selected on the main desk. I use a wing (obviously not on the same page as the main desk) plus a midi keypad to fire playbacks on yet another page - very annoying being unable to see these without changing pages on the main desk (I always forget to change back for one thing). If view+page up/down or view+cursor left/right (or up/down) aren't doing anything then they might be ways to select the page (sorry FLX-S users) but I expect you'll think of something. Medium - Midi notes/cues. As it stands this operates on the currently viewed playback. Would it be possible to add an option in setup to select a particular playback instead. "Currently viewed" is just too vague for my purposes. Low - I've had the occasional problem when I have inadvertently hit channels/playback, page up or page down. Might be nice to have a way to lock these (press and hold for a number of seconds maybe). Quote 2 x FLX with Raspberry Pi's running TouchOSC, ZerOS Wing, Leapfrog, Jester M24L Eurolite ArtNet/sACN nodes. ChamSys MagicQ compact connect with MagicQ/PC Regular tech in two Milton Keynes music venues plus occasional festival work.
Sven76 Posted September 23, 2019 Report Posted September 23, 2019 Hi all, cool Idea. Let's hope the ZerOS gods are merciful to us 😉 My most missing features are: - Pixelmapping/Matrix (yes it is in W.I.P. but really really need it. The sooner the better) - Independent "real" FX-Masters to independently scale FX Size and FX Speed. I never understood why speed and size were bound together. Best regards Sven Quote
martin-144 Posted September 23, 2019 Report Posted September 23, 2019 To avoid the "Surprise, Surprise" moment: Possibility to have submasters not recorded in other cues. No, the inhibit or park workaround is not practicable. Thanks, Martin Quote
van den abbeele Eric Posted September 23, 2019 Report Posted September 23, 2019 - indeed have parameters at the level of effects that can easily allow to act on speed, or size, or offset or other in a more intuitive way. On version 7.9.4, some parameters can easily go into too big or too small limits, by just changing a few things ... - The ability of some consoles is to be able to have effect palettes playing on the colors, on the gobos, on alternations of events specific to each family of projectors ... How to get to play on some parameters more easily without having to spend an infinite time of programming ... - More freedom on the windows of the external touch screen. - Subgroups or control groups of projectors with more intuitive access and allowing to work faster. - In a global way, to have possibilities through the effect palette to be able to act on a group of projectors more quickly with more effects and access to more effective basic parameters to have a recorded show quickly. Indeed what can easily miss is the time! And if this is not directly related to the new OS, but a manual that repeats the basic events of the current system, and not a version too old ... Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 4 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 4 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 10 LS200 - Spot 200w // 19 Wash Par 12 X 18W // 12 BOWLDER 12X40w WASH // 12 PARZOOM 19 X 15w // 7 LY 400 - BSW CMY LED 400w
Jon Hole Posted September 24, 2019 Report Posted September 24, 2019 (We're not ignoring this thread, but waiting to see where it goes before replying!). Quote Jon Hole linkedin.com/in/jonhole
Afx Posted September 24, 2019 Author Report Posted September 24, 2019 Forgot this: show shifted parameters. ie. I press shift and fan fixtures, the values or the fanning mode cant be seen from anywhere as far as I can tell. Quote
JM3004 Posted October 6, 2019 Report Posted October 6, 2019 Something along the lines of magic sheets, so I can see my rig for a quick selecting, as well as being able to customise this with buttons to perform tasks such as house lighting, some syntax etc. Quote
Uriahdemon Posted October 6, 2019 Report Posted October 6, 2019 Printable Set up sheets i.e. with Fixtures, associated channels and DMX addresses .... thanks. Quote
scottydog75 Posted October 7, 2019 Report Posted October 7, 2019 On 10/6/2019 at 7:43 PM, Uriahdemon said: Printable Set up sheets i.e. with Fixtures, associated channels and DMX addresses .... thanks. I second this, some sort of Excel/CSV output from the fixture schedule would be a great help Quote
Erics Posted October 10, 2019 Report Posted October 10, 2019 High - Support for Fixtures with sub-fixtures for multi RGB(AW) or only multi dimmer channel (for easy handling, creating effekts, need less faders)Medium - Free assignable soft button page for cues or cuelist with assigneable button behavier like flash, toggle, flash + go + release. So you can can programm effekts like strobe, fog, colour flash to it without spending much faders and you can name them easy. Page should be assignable to internal or external touch screen - RDM controls to see RDM parameter from devices and send rdm commands to them Low - usb midi control for FLX S range - customized (dmx) output screen, to see what happening and for easy programming without fixtures connect. with simulation of LED colours and dimmer values Quote I use: Zero 88 FLX S48 / Chamsys MQ70 / Madrix / mostly Astera Lights
Davidmk Posted October 10, 2019 Report Posted October 10, 2019 Free assignable soft button page - Ooo, yes please!!! Quote 2 x FLX with Raspberry Pi's running TouchOSC, ZerOS Wing, Leapfrog, Jester M24L Eurolite ArtNet/sACN nodes. ChamSys MagicQ compact connect with MagicQ/PC Regular tech in two Milton Keynes music venues plus occasional festival work.
kgallen Posted October 10, 2019 Report Posted October 10, 2019 When programming I find the cue stack listing and current/next bar behaviour really annoying - because by definition I'm at the end of the cue stack I'm always working at the bottom of the cue stack list on screen. When playing back then the "next" cue is in the centre of the screen cue list. This is fine. It's when programming it drives me batty... There are some screens provided on Orb that I've seen you chaps using the get more detailed information on cues/fixtures etc when debugging stuff. As you don't sell Orb anymore (so don't need feature-differentiation to FLX) can you port these screens to FLX? Of course now I want one, I can't find an example where you've done this on the forum to show here even though I've been looking for about an hour... 😣 Debugging RDM fixture setup is impossible. Like Erics above, "RDM controls to see RDM parameter from devices" please. I know you have some internal debug screens you use. Looking back there are a lot of ZOS enhancement requests that us early-adopters have raised. Would be good to see some of those make it into the software finally, or at least get some sort of roadmap so we can "reliably" know when to expect them. I'm including the ones from 2015-2016 that have "gone quiet"... Quote
CPlater1 Posted October 12, 2019 Report Posted October 12, 2019 Something quite minor I would like is the ability to set the background of the lock screen to be an image, such as a show image. It's not a vital thing, but I think it looks quite nice. Quote
Uriahdemon Posted October 16, 2019 Report Posted October 16, 2019 Numbering on screen of the playbacks would be a great help please. Quote
martin-144 Posted October 16, 2019 Report Posted October 16, 2019 On 10/10/2019 at 4:49 PM, kgallen said: When programming I find the cue stack listing and current/next bar behaviour really annoying - because by definition I'm at the end of the cue stack I'm always working at the bottom of the cue stack list on screen. When playing back then the "next" cue is in the centre of the screen cue list. This is fine. It's when programming it drives me batty... I agree to that. When programming at the end of the cue stack, the display tends to cut your last cue. And you unintentionaly jump to the first cue causing strange eyes on your director's face. Quote
Afx Posted October 19, 2019 Author Report Posted October 19, 2019 On 9/24/2019 at 11:45 AM, Jon Hole said: (We're not ignoring this thread, but waiting to see where it goes before replying!). Its been a month, anything you can give out? Quote
Afx Posted November 14, 2019 Author Report Posted November 14, 2019 On 10/20/2019 at 12:07 AM, Afx said: Its been a month, anything you can give out? Cmoon! There must be something you can tell, at least acklowledge you got the message? Quote
Edward Z88 Posted November 14, 2019 Report Posted November 14, 2019 Hello, 6 minutes ago, Afx said: There must be something you can tell, at least acklowledge you got the message? Don’t worry - we check the forum regularly and have been keeping an eye on this thread. Really good to see everyone’s thoughts and comments on ZerOS. We have been working hard developing ZerOS 7.9.7 (which there are images of on the forum for people with beta software access), which will include the updated fixture library. This library is required to allow for most of the suggestions and requests in this thread, so we are excited to get this released. If you have any questions let us know. Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
van den abbeele Eric Posted November 18, 2019 Report Posted November 18, 2019 Thank you Edward for considering our requests, but if all is not possible ... (thank a lot for the 7.9.6 PDF manual) In fact it is certain that this console FLX can work with a time of preparation before a show (Theater / dance) or show some time in advance. But the other thing you have to see is that sometimes the time is limited. In this case, having to have - quick access, - FX capable of generating basic things, - speed of movement and amplitudes of easily accessible movements and in fact everything that can take control of LED and Moving Head projectors, will give strength to the FLX (ZerOS) and so can claim in rental companies to have a console that requires hours of preparation for a show that must be mounted quickly. Because playing on a lot of parameters and looking to perfect things is always better, but sometimes we can call us in the morning at 8am for help, or learn that something planned is changing or not having the equipment provided (Pannes , change of rental company, etc ...) and there is a console that can be driven easily and quickly So I'm going to update to 7.9.5 to 7.9.6 with firmware update, and I will see all the news things... Thank Eric Quote 1 FLX + 1 wing "7.14" + 1 FLX "7.13" & 4 Wings / 2 Touchscreen // Jester 24/48 2 Swisson XND-4R5 ENode // Stairville : 4 Wash MZH 19X15w - 31 Retro Flat Par 18X 12w RGBW Electroconcept : 36 Wash 18 X 10w Q188 // ADJ 2 Spot Focus 4Z & 2 Spot Focus 5Z Led 200w - VARYTEC : 12 Varytec Hero Wash 300 FC LedStage : 10 LS200 - Spot 200w // 19 Wash Par 12 X 18W // 12 BOWLDER 12X40w WASH // 12 PARZOOM 19 X 15w // 7 LY 400 - BSW CMY LED 400w
SimonH Posted November 22, 2019 Report Posted November 22, 2019 Something similar to the @copyfrom from my old strand days Quote
MylesBSN Posted December 6, 2019 Report Posted December 6, 2019 High: Assign one fixture multiple dimmers (multiple brightness attributes), Soft buttons on FLX S for home, max and default and for UDKs. Medium: Visualisation of light (color, possibly gobo if image provided and rough direction aim of light), FX constuction for FLX S. Low: Ability to create fixture profiles on desk (give start address and work from there, you can control the light and figure out what the values are for boundaries etc). Quote
Edward Z88 Posted December 6, 2019 Report Posted December 6, 2019 Hi Myles, Thanks for the comments. 1 hour ago, MylesBSN said: Soft buttons on FLX S for home, max and default Could you expand a little on this one? FLX S already has the Home button which can be used for homing fixtures, and configuring Max Level and Defaults... 1 hour ago, MylesBSN said: UDKs What would you like to be able to do with UDKs on FLX S? Do you find you would need these as well as playbacks? Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
MylesBSN Posted December 9, 2019 Report Posted December 9, 2019 On 12/6/2019 at 11:05 AM, Edward- Z88 said: Could you expand a little on this one? FLX S already has the Home button which can be used for homing fixtures, and configuring Max Level and Defaults... What would you like to be able to do with UDKs on FLX S? Do you find you would need these as well as playbacks? On the FLX S24/48 there are no home buttons or UDKs like on the FLX unless i haven't found them, soft UDKs would be useful so we can access RemDim and Highlight etc. Currently when i want to add max levels or ajust home etc i have to save the show and load it on a phantom instance of the FLX which is a pain as i generally only get 2-3 hours to set up every thing. Edit: I have just found the home function, however i would be interested to see this more clear in the documentation because i have not seen this anywhere. Quote
Edward Z88 Posted December 9, 2019 Report Posted December 9, 2019 Hi Myles, 48 minutes ago, MylesBSN said: Edit: I have just found the home function, however i would be interested to see this more clear in the documentation because i have not seen this anywhere. This is on Page 24 of the manual. https://zero88.com/storage/downloads/7f906b85-80f1-4646-bd18-d2327d94fc60/FLX-Range-&-ZerOS-Accessories-User-Manual-v7.9.6.pdf More information can be found here... http://support.zero88.com/1011411491 Hope this helps, Edward Quote Edward Smith Formerly: Zero 88 Product Specialist - Email Support Currently: Obsidian Control Systems Product Specialist
